Modify Panorama Menu css classes?
Treto
Liked in: 7 posts
by Treto » Wed Nov 22, 2017 8:08 pm
Hello:
I would like to add a few css classes to the Panorama Menu plugin text. Upper case, letter spacing, etc.
I can not locate the css file/content in the build files make the edits.
Can someone tell me exactly where this is located?
Thank you,
Treto
Re: Modify Panorama Menu css classes?
by Annis » Fri Nov 24, 2017 11:47 am
The Panorama Menu is controlled both in the xml and js, so I don't know if there's much you can control through the css without risking breaking the plugin's functioning. I don't know where you can find the specific classes for this plugin.
