Within Image Gallery >>> Zoom
rruiz
Liked in: 5 posts
by rruiz » Sat Nov 11, 2017 12:21 am
Is it possible to have zoom within images of Gallery Plugin ??
or
Someone have resolved this topic... having zoom ?
Re: Within Image Gallery >>> Zoom
by Destiny » Sat Nov 11, 2017 5:31 am
Hi, you have a couple of options...
You could use a Website Box and add a zoomable galley into that.. Like Zoomify... Or you can use PTP, using the flat image option, make a seperate project then then add that into a Website Box..
Annis likes this post.
neofilm
by neofilm » Mon Feb 19, 2018 11:29 pm
So many people with this problem. Can't they develop this obvious feature? Why don't they just make it so all images are by default able to be zoomed into? This seems so obvious to me. When the visitor is in a pano and clicks on a image and the image pops up there is no reason to zoom into the background behind the image. All zooming should now be on the image in the foreground! I explain this issue in this video here: https://youtu.be/vrrr5xUJjP0
