questions. Panotour Pro
jin
by jin » Sat Nov 04, 2017 3:55 pm
Hello.
Panotour Pro 2.3 users
There are two questions.
If you follow the path below, you can see the example screen.
http://www.360map.co.kr/test/test/
1. The first screen is "A" red.
Click on B to dissolve to blue B.
Question = I want to reduce the dissolve time.
(The background color of the project is white. / action, Basic > Go to a panorama)
2. Select -> "A"
I see a black screen.
Question = I want to create a white transition.
(action, Basic > open a website)
I want the answer as detailed as possible.
bgcolor-1 (index-xml).jpg (37.1 KiB) Viewed 361 times
Likes: 14 posts
Re: questions. Panotour Pro
by bdd » Tue Nov 14, 2017 2:22 pm
Answer to first question :
1- edit the generated XML file :
http://www.360map.co.kr/test/test/index ... x_core.xml
2- find the definition of "ptblendmode" on line 99 :
         <krpano ptblendmode="BLEND(1.0, easeInCubic)" />
3- change the value of the first parameter of the "BLEND" call
like described in the krpano documentation :
https://krpano.com/docu/actions/#loadpano.blend
Answer to second question :
1- you can try to set an invalid value to the bgcolor of both tours, but you'll have to set a background to the HTML page :
See the krpano documentation about bgcolor and transparency here :
https://krpano.com/docu/xml/#krpano.bgcolor
Please remember that we do not offer KrPano support.
Hemant 3d
by Hemant 3d » Tue Nov 14, 2017 6:45 pm
Why PTV file Failed to send on Email...???
