Set default screen size and HMD-Preset
alex_t
by alex_t » Fri Nov 03, 2017 9:28 am
Hello!
We are doing a VR-Tour through a building with rendered Stereo-Panoramas. The Client has provided us with a number of Gear-VRs and Galaxy S7 edges - this is the only platform this tour will be displayed on.
When we load up the tour in Panotour Viewer, the default Screen Size is Set to 5 inch and the HMD-Preset is set to custom.
We would like to change it, so that the default Screen Size is 5,5 inch and the HMD-Preset is set to Gear-VR in order to avoid having the client needing to set it manually on every startup on every Phone.
(If we set these parameters in the Panotour-Viewer Settings window manually and hit save, it doesnt do anything?)
Is it possible to edit for example the .xml file to achieve this?
Any help would be very much apprechiated!
greetings from germany
Likes: 60 posts
Liked in: 169 posts
Re: Set default screen size and HMD-Preset
by benji33 » Fri Nov 03, 2017 1:12 pm
Here it's the GoPro VR Player forum page. The forum page for the Panotour Viewer is here : viewforum.php?sid=&f=97
Which version of Panotour are you using to generate the tour please?
alex_t
by alex_t » Fri Nov 03, 2017 1:59 pm
Oh i was not aware of that, thanks ;)
Its Panotour PRO 2.5
Users browsing this forum: No registered users and 9 guests
