VRmode - remove button   [SOLVED] - View the solution
ccc23444
Liked in: 6 posts
by ccc23444 » Sat Oct 21, 2017 10:12 pm
When I enter VRmode by clicking the glasses-icon, I get this picture up.
A set of glasses with a panopreview.
I have to click on the panopreview again to enter the tour with VRgoggels
Is it possible to bypass this an go directly to the tour?
Best regards
Jesper
signmaster
Likes: 52 posts
Liked in: 36 posts
Re: VRmode - remove button
by signmaster » Sun Oct 22, 2017 7:46 am
I think this is normal as you need to select the correct HMD (Head Mounted Display) before entering the tour. Makes a big difference selecting the correct HMD.
ccc23444
Liked in: 6 posts
by ccc23444 » Sun Oct 22, 2017 9:32 am
The preview and the button just makes no sense. You dont choose your HMD there. It is just a "Go-on" button
On the following screen you get to choose the HMD. On my phone the HMD is selected automatically (or from the last time i used it).
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Sun Oct 22, 2017 10:39 am
Yes you are correct, my mistake.
by Annis » Mon Oct 23, 2017 10:13 am
You can't skip the VR Mode intermediary screen, it's needed to launch the tour in fullscreen and activate any videos you have in the first scene so that you don't need to touch the screen for those videos to start, among other things.
signmaster likes this post.
ccc23444
Liked in: 6 posts
by ccc23444 » Mon Oct 23, 2017 2:21 pm
Hi Annis
Ok. I’ll live with it :)
Best
Jesper
by benji33 » Wed Oct 25, 2017 8:30 am
If needed this screen can be customized with krpano code.
The code linked to it is into the YOURTOUR_core_vr.xml file. There is a webvr_enterbutton layer which contains the 3 layers for text, button and thumbnail with webvr.enterVR(); action.
Annis likes this post.
