Panotour Maps - Google Satellite view   [SOLVED] - View the solution
pbetancourt
Likes: 25 posts
Liked in: 7 posts
by pbetancourt » Fri Sep 08, 2017 4:43 am
I'm trying to use Panotour Maps to show Google Maps Satellite view. I have created and applied my API key, and the road view is working fine, but If I switch to satellite view I get an error message from google:
pbetancourt
Likes: 25 posts
Liked in: 7 posts
Re: Panotour Maps - Google Satellite view  [SOLVED]
by pbetancourt » Fri Sep 08, 2017 5:23 am
Restricting the credentials API to certain sites solved the issue.
