Display an Image over the Tour
rruiz
Liked in: 5 posts
by rruiz » Sun Sep 03, 2017 6:58 pm
If the tour starts showing all the controls... obviously the " Display an Image over the Tour " is been shown, but how do I hide the DISPLAY IMAGE at the begining?
This control doesn´t has the option of : STARTS CLOSED...
Or is there another control that can show an image that I can control it?
Re: Display an Image over the Tour
by Annis » Mon Sep 04, 2017 3:10 pm
I don't understand, what are you looking to do exactly?
Show an image before everything loads (splashscreen) or ...?
rruiz
Liked in: 5 posts
by rruiz » Mon Sep 04, 2017 10:32 pm
When I open my tour, the image of the middle( Display an Image over the Tour ) is been shown with all the rest of the elements.
I want this image to be shown not at opening the tour... only when it´s bottom is been cliced
Regards
(NOte: don´t put attention to the arrow... put attention to the image at the middle of the screen)
by Annis » Tue Sep 05, 2017 9:42 am
How is it displaying now? If it shows on the click of a button you need to click the button for it to display, but if it's showing at the start of the tour you have it set somewhere else to display too.
Check you haven't set it as a splashscreen, and also check you haven't got an instance of the CAOTE plugin set to display that image on tour start.
Siewers
Likes: 4 posts
Liked in: 14 posts
by Siewers » Thu Sep 07, 2017 4:18 pm
I've got the same problem, I fix it now with the CAOTE plugin
It is not optimal but works
by Annis » Thu Sep 14, 2017 10:33 am
Could you describe what the issue is then? I'm afraid I still don't fully understand.
If you explain I can file a bug report or feature request, depending on what the issue is.
Siewers
Likes: 4 posts
Liked in: 14 posts
by Siewers » Thu Sep 14, 2017 10:57 am
the "Display an Image over the Tour" plugin starts opened when you add it to a tour, it should start closed? or have a option start closed
by Annis » Thu Sep 14, 2017 11:01 am
Oh so the Picture plugin?
I see. It's meant to be used for graphic elements like logos or banners or whatever, so it isn't really planned for that use.
I'll add a feature request for it to start closed then, but yes the CAOTE plugin will work for now.
If you're clicking elsewhere to display it though, why not just use the Display an Image action instead? It won't start open it only displays when you trigger it...
by Annis » Thu Sep 14, 2017 11:05 am
Thank you for explaining btw. :)
Siewers
Likes: 4 posts
Liked in: 14 posts
by Siewers » Thu Sep 14, 2017 11:08 am
I tweaked my plugin to be clickable so I can add action to the image, makes it a lot more versatile :-)
by Annis » Thu Sep 14, 2017 11:09 am
If you want it clickable then why not use a button?
You would still need CAOTE to hide it on tour start though.
