Oculus Rift - how to display my ptp tour?   [SOLVED] - View the solution
frank007
Likes: 12 posts
by frank007 » Thu Aug 31, 2017 3:28 pm
Hi Folks,
my client wants to have a version of the tour for the oculus rift. how can I do that with PTP? I do not see any options to choose the rift as the glasses. Only VR ONE, GearVR etc.
Thank you!
Best regards
Frank
Re: Oculus Rift - how to display my ptp tour?  [SOLVED]
by benji33 » Fri Sep 01, 2017 10:44 am
1. You need an Oculus Rift + Oculus Home installed.
2. You also need Firefox into it's latest version or the Chromium experimental build with correct setup. Have a look here for the setup : https://webvr.rocks/
3. Launch the virtual tour in VR mode with the add of ?vr at the end of url, click on the entrance screen.
4. The VR should be available on your HMD directly.
frank007 likes this post.
