Hotspot over polygon?   [SOLVED] - View the solution
pbetancourt
Likes: 25 posts
Liked in: 7 posts
by pbetancourt » Fri Aug 04, 2017 1:13 am
I'm building a tour with both polygons and hotspots. The problem is that polygons are over some of my hotspots and I cannot click on them. Any way to get the hotspor OVER the polygon? with polygons the layer order depend on what did you draw first, but here I don't know how to solve it.
Captura de pantalla 2017-08-03 a la(s) 21.08.19.jpg (33 KiB) Viewed 1091 times
Many thanks
Re: Hotspot over polygon?
by Annis » Mon Aug 07, 2017 1:15 pm
You should place the polygons before the point hotspots.
Otherwise, edit the xml to change the zorder of the hotspots to bring your point hotspots forward.
mikepostons
Likes: 4 posts
Liked in: 5 posts
by mikepostons » Tue Oct 10, 2017 2:36 pm
Just ran into the same issue. Created the polygon first and then added the hotspot second. The Polygon still ended up above the hotspot? Can anyone give an example of where the z-order needs to be changed in the XML, there are a lot of instances of z-order in that file.
Re: Hotspot over polygon?  [SOLVED]
by Annis » Mon Oct 16, 2017 4:12 pm
Try what's mentioned here: https://krpano.com/forum/wbb/index.php? ... #post66049
Try adding renderer="css3d" to the point hotspot's code so that it displays above the polygon. It might be enough to put it directly in the hotspot style (in the _skin.xml) instead of each individual hotspot.
mikepostons
Likes: 4 posts
Liked in: 5 posts
by mikepostons » Wed Oct 25, 2017 1:14 pm
Thanks @Annis that worked great. Only needed to add to _skin.xml file. Only issue is the XML file obviously get overwritten on each build. My solution to this is create a backup of that file (with render="css3" added to the specific spots) and then delete and replace the new file that is built. Unless there's a more permanent solution?
by Annis » Wed Oct 25, 2017 1:48 pm
Yes every time you rebuild the tour the xml is overwritten.
If you know which spot style you are using you could create an xml file to include using the "include an xml" plugin. http://www.kolor.com/wiki-en/action/vie ... ude_an_XML
That way your bit of code is automatically added on tour build instead of being rewritten in the tour's xml.
Say for example this is your spot style (don't mind my spot name ;) ):
<style name="IconGRAAAAARG"
url="%FIRSTXML%/spots/hotspot_plan_user_defaultpoint5.png"
visible="false"
onhover="onhoverIconGRAAAAARG"
onout="onoutIconGRAAAAARG"
Instead of adding renderer="css3d" to the spot style, copy the code for your spot style into a new xml file. Keep the name and get rid of the rest, and this time add renderer="css3d". So with my example it'd become something like:
renderer="css3d"
Save that file somewhere on your computer (I save all the include files in the Panotour user directory for safe keeping) and point to that file with the Include an xml plugin.
This should work, but I'm not much of a coder...
mikepostons
Likes: 4 posts
Liked in: 5 posts
by mikepostons » Wed Oct 25, 2017 1:49 pm
Thanks Annis, that's really helpful I will give it a go! Cheers
Annis likes this post.
