Embed a pano inside Power Point or Keynote?
pbetancourt
Likes: 25 posts
Liked in: 7 posts
by pbetancourt » Wed Jul 12, 2017 3:54 pm
Hi friends, is there any way to embed an interactive 360 pano inside Power Point (prefered) or Keynote? I've found some plugins that allow inserting an iframe, but then you need internet connection. Any workaround to have them working locally and keep interactivity?
Many thanks,
Pablo
Re: Embed a pano inside Power Point or Keynote?
by Annis » Wed Jul 12, 2017 4:05 pm
Other than the iFrame route, I'm not quite sure.
You'd need to have a local webserver running, then the link to the file on the server and display that in an iFrame.
Maybe try this with the Mongoose webserver.
Have it set to open on the folder where your tour is located, and copy the localhost url for that and try displaying it in an iFrame. I don't know if it'll work and do not have PowerPoint to test.
If it works, then each time before your presentation you'll need to have activated Mongoose so that it can display.
pbetancourt likes this post.
