internet line speed of webserver vs. youtube integration
Christian Stüben
Likes: 3 posts
Liked in: 9 posts
by Christian Stüben » Mon Jul 03, 2017 6:43 pm
Hi all,
as i just have seen, the internet connection speed of my webserver is too low for some looong 360° videos. When i integrate into my panotour pro project, most of the viewers only get a still picture of the first frame, but not the moving video.
So my question ... can i integrate youtube 360° videos with a similar "look and feel" as real integrated 360-videos?
Yes, the control elements will look differently, that´s obvious :/
greetings from germany
Chris
Re: internet line speed of webserver vs. youtube integration
by Annis » Mon Jul 10, 2017 12:35 pm
You could open them fullscreen above the tour, in the webvideo box but you wouldn't have any of the tour's interface.
This could work only if you're using the videos as an intermediary between scenes, so you would basically have your pano, click on a spot to change scene which opens your video box, after a delay change the scene and after another delay (length of the video) close the webvideo box.
In other situations though, I don't have a solution for you unfortunately.
Christian Stüben
Likes: 3 posts
Liked in: 9 posts
by Christian Stüben » Fri Jul 14, 2017 7:21 pm
Yes, the webvideo box, or a similar "external html window" is the "last exit" i already had, but tried to avoid.
I would have preferred any kind integrated solution.
Thank you for the confirmation.
greetings from germany, Chris
