VR HMD Transition time
kingo
by kingo » Tue Apr 25, 2017 9:06 am
There are no settings for the Transition times when using VR HMD. I use the HTC Vive and it can take between 5-8 seconds to transition or sometimes will not transition at all.
Can you please advise which XML file has the code to change the Transition/look to activate time ?
thanks
Re: VR HMD Transition time
by klausesser » Tue Apr 25, 2017 10:49 am
kingo wrote:Hello,
thanks
Hi!
Use "xyz_vr.xml" or/and "xyz_core_vr.xml".
