Mobile tour with floorplan
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Fri Apr 21, 2017 6:53 am
Would anyone have an example of a mobile compatible tour with a floorplan?
Steve
Re: Mobile tour with floorplan
by Annis » Fri Apr 21, 2017 2:14 pm
What do you mean?
All tours are mobile compatible.
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Fri Apr 21, 2017 2:34 pm
Mobile compatible, but a lot of thought has to go into making them mobile-friendly. So I would like to see some examples, especially with a floorplan.
Steve
SBV360VR
by SBV360VR » Sat Apr 22, 2017 8:46 pm
I am working on this tour - http://droneschoolbr.hospedagemdesites. ... index.html
I am using Floor Plan with a mobile version
But I am having some problems.
It runs smooth on Android Devices, and Iphone 6, 6S and 7 but when I try to run it on 6+, 6S+ and 7+ it runs with the same config as Tablets
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Sun Apr 23, 2017 11:22 pm
Very hard to put a tour together that works well and easy to use on mobiles. The sidebar on your tour should collapse to a hamburger on smaller mobile screens and the floorplan should fill the complete screen. Both are a bit too small to easily use.
