Product Photography
Korben5
Product Photography
by Korben5 » Thu Apr 06, 2017 5:17 pm
I've been using Panotour Pro for a while now to create virtual tours and I absolutely love the software. I'm trying to get into 360° Product Photography (shooting a rotating object) and have been playing around with something called Shutter Stream, but I really don't like it. Do any of the Kolor applications have the functionality to create 360° product shots?
Re: Product Photography
by Destiny » Fri Apr 07, 2017 12:50 am
Hi.. Basically, no...
KRPANO have an option but I think that is flash.. Garden Gnome have ObjectVR...
http://www.destinyvirtualtours.com/Obje ... eVase.html
You can also use Zoomify Object...
http://members.westnet.com.au/dps/360St ... ebsite.htm
by Annis » Fri Apr 07, 2017 8:45 am
As Destiny said, we don't none of our software allows the creation of 360 objects. You would be looking for something more along the lines of Object2VR.
However, if you create 360 objects that can be placed in an html file, you can open this in a virtual tour in a website box or web content spot.
SBV360VR
by SBV360VR » Sun Apr 09, 2017 12:03 am
Are you using shutter stream or shutter stream 360 ?
