Hotspot help
cmsmits
Hotspot help
by cmsmits » Wed Mar 22, 2017 7:00 pm
Hello all,
We are using Panotour to create educational tours and for training purposes
We were trying to determine if there is a way to make hotspots disappear after you click on them in the tour.
Thank you!
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
Re: Hotspot help
by 360-compunics-com-ni » Wed Mar 22, 2017 7:40 pm
Have a look at the "find objects game"-plugin available here: http://www.kolor.com/wiki-en/action/view/Panotour_-_Advanced_-_Extra_Plugins#Find_Object_Game.
The hotspots disappear when clicked, and you can define an action to be performed once the max counter has been reached.
Annis likes this post.
cmsmits
Re: Hotspot help
by cmsmits » Fri Mar 24, 2017 9:26 pm
We are having trouble installing this plugin into panotour.
Where would it show up in the style section? We are not seeing the plugin in the plugins library.
Likes: 15 posts
Liked in: 163 posts
Re: Hotspot help
by 360-compunics-com-ni » Fri Mar 24, 2017 9:30 pm
The plugin should appear in the "User input" category.
At the top of the download page there are installation instructions, have you followed them?
Re: Hotspot help
by Annis » Mon Mar 27, 2017 10:16 am
Did you restart PTP after installing the plugin?
Also, the Find Objects should have had a plugin category of it's own (Fun) but I must have uploaded the wrong version.
cmsmits
Re: Hotspot help
by cmsmits » Wed Mar 29, 2017 5:53 pm
Still no luck,
I have installed other plug-in's before and after trying to remove it and re-install several times I still am not seeing the plug-in in User Input library or in a separate library.
Any suggestions?
Re: Hotspot help
by Annis » Thu Mar 30, 2017 8:13 am
Can you show me a screenshot of the plugin's location, make sure it shows the filepath.
Something like this:
Kaj
Re: Hotspot help
by Kaj » Thu Sep 13, 2018 8:54 am
Is the "FindObjectsGame" convertible with Mac?
Re: Hotspot help
by benji33 » Fri Sep 14, 2018 7:58 am
Find Object Game is working on macOS of course and is now part of the software bundle (2.5.14 version). No need to add it into your Panotour Pro user directory.
