insert a javascript function
Likes: 14 posts
Re: insert a javascript function
by bdd » Tue Mar 21, 2017 10:41 am
Why don't you react on the "onidle" event from krpano ?
https://krpano.com/docu/xml/#events.onidle
by Annis » Tue Mar 21, 2017 5:07 pm
Have a look at my post here: viewtopic.php?f=91&t=35362&p=196128#p196128
Depending on what you're trying to do, you could incorporate the krpano code using the action Call KrPano Code, or create an xml file to integrate to the project using the Include an xml plugin.
You can download either or both here: http://www.kolor.com/wiki-en/action/vie ... ra_Plugins
by Annis » Wed Mar 22, 2017 9:19 am
Please keep issues separate, one topic per issue.
The CAOTE issue is separate, nor do I understand what is happening. Please create a new topic and perhaps illustrate the issue or show me your plugin's parameters so that I can recreate the issue on my side.
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Sat Mar 25, 2017 6:35 pm
"idletime" expects the time given in seconds, so if you want to wait 5 minutes set it to 300.
And the event "onidle" expects as functioncall the name of the action to perform, so instead of setting it to 5, call the action as follows:
onidle="goto();"
likes this post.
