Blendig while rotating - i asked here how to do it in PTP   [SOLVED] - View the solution
by klausesser » Fri Mar 17, 2017 9:43 pm
http://klausesser.de/EllerBlend/
One litte stutter in the first rotion - after that no more.
Done in KRPano
And here made in PanoTour Pro 2.5.7
http://klausesser.de/Eller_Blend/
A stop of about 2 seconds on the blending point. Keeps this way on EACH rotation.
Re: Blendig while rotating - i asked here how to do it in PT
by Destiny » Sat Mar 18, 2017 12:21 am
Did you change the rotation setting to 0s.. I think the default is 2s..
by klausesser » Sat Mar 18, 2017 6:38 pm
Destiny wrote:Did you change the rotation setting to 0s.. I think the default is 2s..
I set the speed to "10" - because the blending takes place after a full rotation.
btw.: http://www.klausesser.de/D_N (KRPano)
Re: Blendig while rotating - i asked here how to do it in PT  [SOLVED]
by Annis » Mon Mar 20, 2017 12:07 pm
Your particular example is not possible from PTP.
I already told you how to create something similar in one of your previous topics, you need to set autotour on a timer (load new scene after a certain time) and then edit the xml so that autorotation is still active even when interacting with the tour.
However it isn't smooth, it isn't exactly what you're looking for but something similar, and it requires you to take the time to edit your tour.
