paths in Osm with Panotour pro
panolingua
by panolingua » Thu Mar 16, 2017 12:45 pm
I am using Ptp 2.5 on a 64 bit pc with 4gb ram with win10.
I have a question about the map plugin.
I would like to use OSM for my tours. I know I can place hotspots on the map.
Is it possible to place a path on the Osm "connecting" the hotspots to show my own paths?
If yes, how?
Thank you for any hints.
Giuseppe
Re: paths in Osm with Panotour pro
by klausesser » Sat Mar 18, 2017 6:44 pm
Hi Giuseppe!
What is "OSM"?
panolingua
by panolingua » Sat Mar 18, 2017 7:05 pm
Hi Klaus,
Sorry, I meant OpenStreetMap: I would like to use the Map provided by Openstreetmap in my tours.
There is a map plugin in Panotour pro which allows to use this map.
It is possible to place hotspots on this map.
My question is:
is it possible to trace a path on the map, for example a path connecting all the hotspots I place?
Thank you
by klausesser » Sat Mar 18, 2017 7:50 pm
panolingua wrote:Hi Klaus,
Ah - ok!
Thanks for the information!
by Destiny » Sat Mar 18, 2017 10:36 pm
Hi.. When API is added into PTP, you might. Not sure.. But at the moment, no its no possible...
panolingua
by panolingua » Sat Mar 18, 2017 11:23 pm
Hi Destiny,
thank you for the info.
Giuseppe
