Partial Panoramas are Warped
gholder26
by gholder26 » Sat Mar 04, 2017 5:35 pm
I am trying to load some partial panoramas into a tour and most of the pans show some type of warpage. Is there a solution to this? Some scenes do not require a full 360 and I shoot accordingly... Loading the images into another system is fine. I am using Autopano to stitch although I tried other programs and same result...
Re: Partial Panoramas are Warped
by Destiny » Sat Mar 04, 2017 9:43 pm
Hi.. Click on the pano in the Tour tab, then click on the Output Projection to Flat...
gholder26
by gholder26 » Sat Mar 04, 2017 10:42 pm
Thank you for the response but that does not solve the issue. Actually worse as the original image showing the bow of the stitched image is shown. I need the scene to rotate as the full 360's. I have other tours where this is not an issue...
gholder26
by gholder26 » Sat Mar 04, 2017 10:49 pm
I saw in another post that Autopano can turn a partial into a full... Can anyone explain how that is performed?
by klausesser » Sun Mar 05, 2017 2:43 am
gholder26 wrote:I am trying to load some partial panoramas into a tour and most of the pans show some type of warpage. Is there a solution to this? Some scenes do not require a full 360 and I shoot accordingly... Loading the images into another system is fine. I am using Autopano to stitch although I tried other programs and same result...
Please provide some examples of what you do. "some partial panoramas" can mean many different things.
What means "partial" precisely? Half? Quarter? "Partial" in terms of height?
What exactly means "some type of warpage"??
gholder26
by gholder26 » Sun Mar 05, 2017 3:12 am
Thank you for the response. Partial to me means anything less than 360 degrees. My rotator goes in 15 degree increments and some times I will shoot 6 images from left to right for a 180 pan. This is due sometimes to room size or possibly to keep unwanted items out of the scene...
I will need to rebuild the tour with the effected images and provide a link to the tour to show you an example. This will take a while... but attached is a screen shot of one image that shows the issue
bottom of the image the rail is bowed or warped...
by klausesser » Sun Mar 05, 2017 3:13 pm
gholder26 wrote:Thank you for the response. Partial to me means anything less than 360 degrees. My rotator goes in 15 degree increments and some times I will shoot 6 images from left to right for a 180 pan. This is due sometimes to room size or possibly to keep unwanted items out of the scene...
Given you have a FOV of less than 360x180°, a way handling it is to crop it in PTP´s editor. In that case
PTP creates a result with a limited - but unwarped - panorama. The moves then just are restricted to the FOV
of your content - but as said: nothing´s warped.
