remove context menu on public touch screen   [SOLVED] - View the solution
aircamera
by aircamera » Thu Mar 02, 2017 12:34 pm
Hi !
I'm displaying one of my tour on a public touchscreen.
But everyday, after a few hours, people can get out of the page.
I understood how they do :
They touch and hold screen for 1sec, which makes appear the context menu.
Then the link to KRpano and PTP opens a new window. And sometimes, they can even go on youtube !
How can I remove the context menu ?
Thank you for your help !
Re: remove context menu on public touch screen  [SOLVED]
by Annis » Thu Mar 02, 2017 12:47 pm
To remove the references to KrPano and Panotour in the contextual menu, you need a Branding Free Licence.
Once that's registered, the context menu will be gone unless you add a contextual menu plugin to the tour (which I doubt you would for this project in any case).
