How to make thumbnails bar responsive/ follow webpage size?   [SOLVED] - View the solution
LBernos
Likes: 47 posts
Liked in: 7 posts
by LBernos » Mon Feb 27, 2017 7:22 pm
Hello!
I have a thumbnails bar on my tour, the problem is when you view it on chrome or safari, it stays on it place and doesn't automatically adjust its size therefore overlapping the other components on the page..
How can I make it responsive so it wont overlap on the other components on my tour
here's a sample screenshot of my problem:
Thanks!
Lino
Re: How to make thumbnails bar responsive/ follow webpage si
by Annis » Tue Feb 28, 2017 11:35 am
None of Panotour's plugins are responsive.
What are your specific plugins settings?
Have you tried viewing the tour on mobile?
Can you share the link to your tour?
LBernos likes this post.
LBernos
Likes: 47 posts
Liked in: 7 posts
by LBernos » Tue Feb 28, 2017 11:58 am
Annis wrote:None of Panotour's plugins are responsive.
Here is the link: https://s3-us-west-2.amazonaws.com/laci ... le360.html
I was just thinking if I enlarge or shrink the browser window, is it possible that the control bar, thumbnails bar and logo will also enlarge or shrink?
Lino
Re: How to make thumbnails bar responsive/ follow webpage si  [SOLVED]
by Annis » Tue Feb 28, 2017 12:12 pm
For that to happen Panotour's plugins would have to take into account the browser window's size and respond by resizing the plugins accordingly.
Since Panotour's plugins are not responsive, this behaviour isn't possible with the current plugins.
Have you had a look at maybe any of the HTML Templates available here? Several are bootstrap based and include their own controls that are responsive.
LBernos
Likes: 47 posts
Liked in: 7 posts
by LBernos » Tue Feb 28, 2017 12:15 pm
Noted Annis. Thanks for the template links! i didn't know that :)
Annis likes this post.
