I am going crazy with this problem: Every time I add a panorama I have to rebuilt the whole tour and must upload this mass of files - all of them! The new pano is ok, but some of the other in the tour look like attachment.
I had a similar problem with one of my tours. I deleted the filename.cache file and it stopped rebuilding the complete tour. If you are using ftp to upload your tour from PanoTour it should only upload the changed files. I host on Amazon S3 so I have to upload manually. So I normally try to work out which files to upload which is normally the main .html file and the graphics, lib, sounds, and spots folder along with all the files in the root of the data folder, *.swf, *.xml, the js and thumbnail file. Also if you have added another panorama you would need to upload that pano folder. Note backup the filename cache file before deleting and proceed with caution. Steve
Thank you signmaster. Very often it works like you have describe that, but i still have the problem when i change or add one hotspot. then there are some panoramas with failure - and at a tour with 90 panoramas it´s hard to find if there are failures and it takes a lot of time to rebuild the whole tour. Problem still exists!
