Panatour buttons   [SOLVED] - View the solution
greytail
Panatour buttons
by greytail » Mon Jan 09, 2017 7:52 pm
Where can I find the "simple buttons" that are mentioned in the Panotour plugins library? Do I have to create the button graphics myself?
Re: Panatour buttons  [SOLVED]
by Annis » Tue Jan 10, 2017 9:18 am
You'll find them in the style tab > plugins library > controls > simple button.
The simple buttons don't come with any default graphics so yes you do have to create your own.
The Controls category of the plugins library is for Panotour Pro only.
greytail
by greytail » Tue Jan 10, 2017 6:03 pm
Thanks, I suspected I had to make my own, but I couldn't find anything on the site that specifically mentioned this requirement.
