Setting up initial Panotour display
greytail
by greytail » Sun Jan 08, 2017 9:44 pm
I am unable to adjust the opening view of a pano I have made. I keep trying to adjust the the zoom and the pitch but it doesn't seem to have any effect.
My pano is here: http://www.maplesyrupvermont.com/panorama/index.html
As you see it does its little planet thing, and zooms in, but needs to point further down so the farm is in the center of the screen. I have tried adjusting the controls but I can't get it to do what I want. I can adjust it the way I want in the preview window but it doesn't save it.
So: what is the workflow for tweaking a panorama..do you keep hitting "build" after making each small adjustment and how do you make what you see the in the preview window happen in the real production?
RoryG
Likes: 3 posts
Liked in: 3 posts
Re: Setting up initial Panotour display
by RoryG » Sun Jan 08, 2017 10:33 pm
Set the view in the preview window then click the "default view" icon, otherwise it won't change. Nice pano by the way :)
greytail likes this post.
RoryG
Likes: 3 posts
Liked in: 3 posts
by RoryG » Sun Jan 08, 2017 10:34 pm
And yes, rebuild after every change.
greytail
by greytail » Mon Jan 09, 2017 12:55 am
okay, thanks very much! got it the way I want to begin it, so after the zoom in, how do I get it to slowly pull out to a 100 per cent and start the slow rotate? Also, what files does it change for something like this...wondering if I can forego uploading the whole thing again.
RoryG
Likes: 3 posts
Liked in: 3 posts
by RoryG » Mon Jan 09, 2017 9:06 am
You don't need to reupload the whole lot every time. If you have made a change that doesn't affect the actual panorama files then just upload the .xml files in the root of your data folder. There's great information regarding the files in a built tour here: http://www.kolor.com/wiki-en/action/vie ... rtual_Tour
