map hotspot color should change when its active
cybervox786
by cybervox786 » Mon Dec 26, 2016 12:01 pm
hello
we are using kolor panotour pro v2.5.5 64 bits, we put map in tour and in map we put hotspot, now our client want option that while those hotspot is active, that hotspot color should change , also while hover on hotspot, hotspot color should change.
regards
sunil
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
Re: map hotspot color should change when its active
by 360-compunics-com-ni » Mon Dec 26, 2016 6:12 pm
as far as i know there is no way to change the mapspot appearance by an "onhover"-event, but you can change the graphics that get displayed for "unseen", "visited" and the active mapspots using the "HotspotsVisited"-plugin available for free from my website at: http://dev.compunics.com.ni/ (description and a demotour available).
Greetings from León,
Michael
Annis likes this post.
