Creating a 360 Video out of a tour?   [SOLVED] - View the solution
Christian Rösch
by Christian Rösch » Fri Dec 16, 2016 9:03 am
Hi kolorteam,
is it possible to create a 360 Grad Video out of a tour which was created in Panotour?
I want to put a tour on youtube for example.
thanks
Christian
Re: Creating a 360 Video out of a tour?  [SOLVED]
by Annis » Fri Dec 16, 2016 9:32 am
Panotour does not export video, a virtual tour is a web page.
You could create a photo slideshow of your panoramas in video editing software, if you mind to keep the 2:1 ratio and run it through the youtube metadata tool then you'll be able to use it as a 360 video in Youtube or Facebook.
by Destiny » Fri Dec 16, 2016 12:10 pm
If you have a Mac, you could capture the Auto Tour via QuickTime. Then perhaps edit the video using a video editing software..
by Annis » Fri Dec 16, 2016 1:42 pm
Destiny wrote:If you have a Mac, you could capture the Auto Tour via QuickTime. Then perhaps edit the video using a video editing software..
That would work to create a normal video, but not a 360° video.
Vishal Mathur likes this post.
Vishal Mathur
Likes: 8 posts
by Vishal Mathur » Thu Dec 22, 2016 3:00 pm
Hi Annis,
So is there a tutorial which can be refered to make a slideshow 360 video from the AGP 4.2 rendered full spherical panoramic images?
I want to create a 360 video which can be played on yourtube & facebook.
Thanks, Vishal
by Annis » Fri Dec 30, 2016 4:26 pm
No we don't have any such tutorial since we don't make editing software.
Use any video editing software that allows you to have control over the output size so that you can make sure the output video has a 2:1 ratio. For example for a 4K 360 video you want the dimensions to be 4096x2048.
Vishal Mathur
Likes: 8 posts
by Vishal Mathur » Fri Dec 30, 2016 5:17 pm
Thanks, now cracked it.
