Image for a single pano   [SOLVED] - View the solution
vista360chile
Liked in: 5 posts
by vista360chile » Fri Nov 11, 2016 3:21 am
Is it possible to use specefic images for specific panos?
something similar to the "small gallerie for a single pano" plug in...
Re: Image for a single pano  [SOLVED]
by Annis » Mon Nov 14, 2016 12:04 pm
Use the Pano-specific Simple Button. Download here: http://www.kolor.com/wiki-en/action/vie ... ra_Plugins
If you don't want it to use an action, just set the action to none.
Using that plugin you can create an entire graphical interface for just a specific panorama. If you wanted to use the same settings on other panoramas but with different images for example, then it's just a matter of duplicating those plugins (so I'd suggest renaming them to organise them properly).
vista360chile
Liked in: 5 posts
by vista360chile » Mon Nov 14, 2016 7:38 pm
Excellent,
That is exactly what i need to do!
Annis likes this post.
