Panorama Combobox Scroll Options   [SOLVED] - View the solution
justinmih
Liked in: 3 posts
by justinmih » Mon Oct 24, 2016 1:06 am
Hi
I have a tour that uses the panorama combobox and the list of panos scrolls off beyond the end of the screen. The way to move down through this combobox list is to click the mouse and drag the list up (icon shows a hand).
My client has asked if this can be made to scroll with the mouse scroll button. Is there an option to change the scroll method for this? If not can it be altered in the xml files?
Regards
Justin
Re: Panorama Combobox Scroll Options  [SOLVED]
by Annis » Mon Oct 24, 2016 8:36 am
There is no option for this in PTP.
We use the basic HTML5 KrPano combobox plugin, I don't know if it's possible even through the xml to set it to react to the mouse wheel, I don't see anything for that setting in the KrPano documentation: https://krpano.com/plugins/combobox/
