Spot Points in VR mode! URGENTTTTT PLEASE!!!
vista360chile
Liked in: 5 posts
by vista360chile » Sun Sep 25, 2016 9:02 pm
Hi Dear Friends
i have just realized that Only those SPOT POINTS with the action "Go to panorama/scene" are kept in VR MOD. spots with ANY other action are removed.
If there is any chance to solve that via hand coding???
Re: Spot Points in VR mode! URGENTTTTT PLEASE!!!
by Destiny » Sun Sep 25, 2016 11:17 pm
Hi.. Is that when you View in VR Mode or When you add another action to the Hotspot(Point Spot) in the Spots Styles.....
vista360chile
Liked in: 5 posts
by vista360chile » Sun Sep 25, 2016 11:57 pm
Hi Destiny
Is when i view in VR mode.
All the hotspots with action different to "Go to panorama/scene" are removed.
In my case, i have a lot of hotpots that show an image when i'm over them. IN VR mode all of them dissapear.
by Destiny » Mon Sep 26, 2016 12:34 am
Did you add and use a new Point Spot from the Library from the Right for other Actions..?
vista360chile
Liked in: 5 posts
by vista360chile » Mon Sep 26, 2016 1:30 am
yes i did it in that way
by Destiny » Mon Sep 26, 2016 2:19 am
If you read here.. You will see that All Plugins are removed in VR Mode... Its a limitation of this feature..
http://www.kolor.com/wiki-en/action/vie ... imitations
What I do not understand is how the navigation hotspots are left but cannot be used, unless they only work on mobiles..
by Destiny » Mon Sep 26, 2016 2:57 am
Hi.. There are extra plugins you can download and try or navigation in VR Mode.. For me they do not work.. Cliquetsy (forum user) created them... So perhaps the Hotspot navigations are supposed to work but not for me... If yo download them, add into the Kolor folder and reboot...
http://www.kolor.com/wiki-en/action/vie ... ra_Plugins
When I try to use the Red Arrows to navigate, the entire screen locks up, so I think there might be a bug since these were written before the new releases of krpano code..
