street view? how to do it?   [SOLVED] - View the solution
Eddie
by Eddie » Mon Sep 19, 2016 11:46 pm
Hello! I finished a project (developed in ptp) and the customer also wants all the panoramas on Google Street View. Someone has a tutorial for how to do?
Thank you!
Eddie
360PRO
Liked in: 3 posts
Re: street view? how to do it?  [SOLVED]
by 360PRO » Wed Sep 21, 2016 1:45 pm
Hi Eddie,
you have to be a Google trusted photographer in order to do this. Then you get the possibillity to create business tours. But you have to start from scratch (ok you have the photo's) and link the panorama's. And there are not so many possibillities in Google business view.
Eddie
by Eddie » Thu Sep 29, 2016 9:33 pm
Thanks, 360PRO! If that is the only way, I will investigate how to be! Trust me..
Eddie
