Editing html for facebook sharing   [SOLVED] - View the solution
mibark
by mibark » Wed Aug 17, 2016 1:33 pm
Hi
I have tried to follow the help page and to edit the html page on how to share on facebook. (http://www.kolor.com/wiki-en/action/vie ... Publishing) on "Only the thumbnail and information with an external link to the virtual tour".
When I share on facebook the thumbnail still dosn't appear. I would appreciate a second look at my html code to see what is missing (I am no programmer and havn't got a clue!).
/thanks
Re: Editing html for facebook sharing
by Annis » Wed Aug 17, 2016 2:18 pm
What's the link to your tour?
Have you run the Facebook debugger on the link? http://developers.facebook.com/tools/debug
mibark
by mibark » Wed Aug 17, 2016 2:43 pm
The link is
http://mikkelbarker.dk/360-panorama-og-film/
I tried the debugger but am not quite sure what it is telling me?
/thanks
by Annis » Wed Aug 17, 2016 3:11 pm
There are three virtual tours on that page.
If you share the actual link to the tours, a thumbnail will show.
If you want a thumbnail to show for the page on your website, you need to edit that page (not the virtual tour) to add the missing tags and thumbnail. If you need assistance you will need to see with your web developer, as we do not provide web development services or support.
marzipano
Liked in: 14 posts
by marzipano » Wed Aug 17, 2016 3:56 pm
Probably not the solution to this problem but I have had postings to Facebook where everything looked OK but the thumbnail didn't show
I discovered that the reason is that there is a minimum size for thumbnails on Facebook and I always make mine greater than 400 x 70 pixels in all directions now
I'm not really sure what the actual limit is but doing this seems to work OK
You can resize the existing thumbnail.jpg using irfanview or similar and just insert this into the web host area without having to upload the whole tour
Martin
mibark likes this post.
mibark
by mibark » Thu Aug 18, 2016 7:59 am
The direct link works! I also tried to erase the facebook cache as I have an updated file, but got the following message -
The 'og:image' property should be explicitly provided, even if a value can be inferred from other tags?
Do you know how I can fix this? My link is
https://s3.eu-central-1.amazonaws.com/d ... sktop.html
Mikkel
mibark
Re: Editing html for facebook sharing  [SOLVED]
by mibark » Thu Aug 18, 2016 8:03 am
Ok, it worked now on facebook! :-)
If people enter my website and the tour from there and pres the share button, how can I get the thumbnail in. Was that a webdeveloper that is needed?
/thanks
