I saw this floating text in a Facebook 360 pano   [SOLVED] - View the solution
MetroRuss
by MetroRuss » Thu Jul 07, 2016 4:09 am
Does anyone know how it is done (it looks awesome), is it done in photoshop directly onto the pano image ? Is it a feature in other VR software platforms? I tried embedding a png file it does work but it has its cons.
Any help is appreciated!
link to the vt https://www.facebook.com/360visitor/pho ... =3&theater
Re: I saw this floating text in a Facebook 360 pano  [SOLVED]
by Annis » Thu Jul 07, 2016 7:58 am
The text was either edited into the equirectangular panorama directly, or the panorama was cut into cube faces to add the text without deformations then turned back into a panorama.
I'm not aware of any image editor that recognises a equirectangular image in input.
MetroRuss likes this post.
jon albert
by jon albert » Tue Nov 15, 2016 12:52 am
Annis wrote:The text was either edited into the equirectangular panorama directly, or the panorama was cut into cube faces to add the text without deformations then turned back into a panorama.
Thanks for your clarification. It helped me lot!
Annis likes this post.
