Hi Is there a way using the "VR Mode - Nadir/Zenith Next button" plugin to skip a pano with Planar projection. I notice that the button will not show on planar projections. Steve
It uses the basic action "go to next panorama" that the prev/next dots plugin uses, so it isn't meant to detect ahead to see the type of scene you'll be navigating to.
Planar scenes don't have a nadir, so nowhere for the button to appear on.
It might be possible to modify the action to skip planar scenes in the xml, but you'll have to find out how.
