Move a polygon spot
signmaster
Likes: 52 posts
Liked in: 36 posts
Move a polygon spot
by signmaster » Fri Jun 03, 2016 5:42 am
This may be a dumb question but how do you move a complete polygon spot? I am working on a project that has a lot of small polygon spots and I need to move the complete polygon once completed to position correctly, some have quite a few nodes. I can select the spot but not actually move it.
Steve
Re: Move a polygon spot
by Destiny » Fri Jun 03, 2016 6:45 am
Hi... As far as I know this is not possible... It would be a handy feature, but I do not think it can be done since the poly lines are drawn on a curve... Or at least they look like they are...
by Annis » Fri Jun 03, 2016 7:55 am
You can't move the entire polygon, it has to be moved spot by spot or remade.
PS: I've moved your topic to the Panotour forum.
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Fri Jun 03, 2016 8:28 am
Thanks, I will stop trying.
Would be a great option especially for the job I am working on.
It would also be good to have a circle and rectangle polygon tool.
Steve
by Annis » Fri Jun 03, 2016 8:36 am
Yes, the hotspot editor as a whole needs to be revamped, which is already on the very long list of feature requests/plans for the distant future.
