Popup Text Window
signmaster
Likes: 52 posts
Liked in: 36 posts
Popup Text Window
by signmaster » Tue May 31, 2016 3:23 pm
Is there a plugin available that will open a text window when a hotspot is clicked?
Steve
Re: Popup Text Window
by Annis » Tue May 31, 2016 3:25 pm
You could either use a description (spot description) or a website box and display a local html file.
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Tue May 31, 2016 11:57 pm
Thanks Annis
I have tried both of them but I need the box to open by clicking on a hotspot. The reason for that is there will be quite a number of hotspots on an image that will require a text box to pop up when clicked. May not be possible?
One solution I have thought of is using the picture hotspot and create an image with the necessary text but this may not work well on all screen sizes?
Steve
by Destiny » Wed Jun 01, 2016 1:10 am
Hi... You can add a Description to a Hotspot.. As many as you like.. As long as you do not have them arrive animated, you can set the Description to auto close on opening a new Description.. Just add the Description Plugin, set the parameters, then asking a Hotspot to the Description.. Each time you add a Hotspot to the Tour an new Description option will be available to add text to... or you can add an image via message xml hand coding..
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Wed Jun 01, 2016 2:34 am
Thanks Destiny
That was most helpful. I am not familiar with xml coding, do you have a link with some instructions?
Steve
by Destiny » Wed Jun 01, 2016 3:27 am
Add some text in the Description so you can recognise the exact line of code in the Message xml..
Then edit it to something like this..
<data name="en_pano9_description"><![CDATA[<img src="full url of your image" width="400" height="300" />]]></data>
aircamera
by aircamera » Wed Jun 01, 2016 8:21 pm
Hi !
I was wondering about the same question.
I'm using pano descriptions for a tour, and a custom simple button makes it appear on left bottom corner or disappear. It works well and I'm happy.
Now, I would like a second button in the menu that displays a second text window. So I created this button, added another description zone on top right corner.
Of course, when I click on the second button, the second window displays the same text than the first one : the pano description. I would like to change this text...
Inside skin.xlm I see this :
<action name="showDescription_description1">
   if(ptplugin[description1].canStart,
      set(ptplugin[description1].descID, get(scene[get(xml.scene)].descriptionid));
      if(ptplugin[description1].descID == null,
         set(ptplugin[description1].descID, "");
      if(ptplugin[description1].descID != "",
         openDescription_description1();
         hideKolorArea_description1(false);
      set(ptplugin[description1].startMethod, "");
</action>
How can I change "get(scene[get(xml.scene)].descriptionid)" with my own text ?
by Destiny » Thu Jun 02, 2016 7:15 am
Sorry to say, you cannot.. I put in for a feature request a while back... You can only auto replace the Description box where no animation has been added... Then it works well..
by Annis » Thu Jun 02, 2016 8:02 am
@aircamera, use a website box to display your text in this case, as a scene can only have one description and buttons do not have descriptions.
aircamera
by aircamera » Thu Jun 02, 2016 11:11 am
Thank you for your help.
I will give it a try...
We need this custom text box in the future...
by Annis » Thu Jun 02, 2016 1:00 pm
You can display anything you want in a website box, so you can add an html file to your tour's data files with all the custom text, images, links, etc that you want.
aircamera
by aircamera » Thu Jun 02, 2016 1:02 pm
I'm trying it right now. Indeed, that's pretty cool !
mgarnier
by mgarnier » Tue Jul 12, 2016 2:33 pm
Destiny wrote:Add some text in the Description so you can recognise the exact line of code in the Message xml..
@destiny: can i also add text and an image in the same Description? I tried your code (screenshot) but it can not display the image. do you maybe know why?
Thanks for your response.
by Destiny » Tue Jul 12, 2016 10:48 pm
Hi... Yes, you can add Text and and Image in the same Description box.. I can see your url is Users.. that means the image is on your system.. You need to upload it to your sever and provide the full remote url..
