Then it's not possible from Panotour, you can't change the panoID from Panotour, and changing it in the xml could break everything else in the tour.
You'd need to create several tours, with different names. You might be able to edit the xml so that you can share the same image tiles accross those several tours, but you'd still need separate tours.
