Google Maps   [SOLVED] - View the solution
FunkyPunky
Likes: 10 posts
Liked in: 4 posts
Google Maps
by FunkyPunky » Sun May 15, 2016 7:58 am
i have read that the use of Google Maps is not free if you use the Google Maps API. Does the Map Plugin in PTP use this API? Have i to register somewhere at Google if i want to use a Google Map inside my Panotour?
Re: Google Maps
by Destiny » Sun May 15, 2016 8:19 am
Hi.. Google maps is free.. You just need to resister it.. Its been a while since I did it.. Its free unless you get a heap and heaps of hits on your website. You can check it out here... https://www.google.com.au/?gws_rd=ssl#q ... ap+api+key Do not share you key...
Re: Google Maps  [SOLVED]
by mediavets » Sun May 15, 2016 1:22 pm
FunkyPunky wrote:Hi,
See: http://www.kolor.com/wiki-en/action/vie ... e_Maps_API
Annis likes this post.
FunkyPunky
Likes: 10 posts
Liked in: 4 posts
Re: Google Maps
by FunkyPunky » Mon May 16, 2016 10:46 am
Thanks!
Users browsing this forum: No registered users and 9 guests
