can anyone please help. i have created my panos in ptgui and have a reasonably small nadir on all of them. i want to place a logo over the nadir on all of them - is there a way to batch process this? i am using panotour pro, ptgui and photoshop
If you're using the same logo for all (and the nadir is actually part of the image even as a black zone, not a missing area) then you could just use the logo plugin and set it on the nadir. Or select all your panoramas in the workspace that are full 360x180° panoramas and add a nadir patch in the scene properties.
Yes, either with the logo which will apply it to all of them, or with the nadir patch option, it'll apply it to all the ones you've selected in the workspace (if you wanted to use several different logos for example)
