18 different floor plans - 18 buttons?
frank007
Likes: 12 posts
by frank007 » Fri Apr 29, 2016 2:08 pm
Hi folks,
I am just editing a tour on a golf course. I would like to show 18 different buttons like these:
Each button must show the specific plan of the golf lane. Any idea how to do that?
Thank you!
Best...
Frank
Re: 18 different floor plans - 18 buttons?
by Destiny » Sat Apr 30, 2016 6:47 am
Hi Frank... You might want to consider a Multi Floor Plan. Here is a mockup..
http://www.destinyvirtualtours.com/Golf ... rplan.html
frank007 likes this post.
frank007
Likes: 12 posts
by frank007 » Wed May 04, 2016 7:37 am
Thank you Destiny. Yes, I tried that. But my question is if I can show several buttons. And each button opens a differnt floor plan.
Best..
Frank
by Destiny » Wed May 04, 2016 10:04 am
Oh I see.. Well.... I just checked out the options.. I guess it might be able to be done via hand coding but not sure.. The issue is, PTP only allows for a single floorpan per pano.. I guess it was not designed for what you have in mind.. The One Button opening a Multiple floorpan plugin is the best that can be achieved via the GUI.. I am not really a fan of hardcoding unless I can make it into a Template, otherwise it has to be edited each every time the Tour is built..
Perhaps a Future Request.. It sounds like a useful extra plugin.. Kolor might have a better solution for you...
by Annis » Wed May 04, 2016 10:04 am
No the action is only open the floorplan module, it doesn't open on a specific floorplan.
It might be possible by editing the xml, but it definitely would not be an easy task, you would have to post on the KrPano forum for assistance or ask if it actually is possible.
