Vr Mode don't work what we are doing wrong?   [SOLVED] - View the solution
Air Photo Colombia
by Air Photo Colombia » Tue Apr 12, 2016 11:03 pm
Hi every one, we add this feature for test in one of the panoramas but this don't work in mobile devices.
here is the link we activate all make all the posible actions but nothing happened. thanks.
http://www.sanandresislandpreview.com/p ... ndres.html
Re: Vr Mode don't work what we are doing wrong?
by Annis » Wed Apr 13, 2016 8:14 am
You're missing javascript files in your uploaded tour:
Make sure they were uploaded and if not upload them.
Did you use PTP's FTP tool or a real FTP Client?
Air Photo Colombia
by Air Photo Colombia » Wed Apr 13, 2016 7:19 pm
Hi Annis That is how the software give the files those are all the files that i recibe from the software.
but i re upload all the example to be shure, can you check again thanks.
by Annis » Thu Apr 14, 2016 8:13 am
If they are on your server, then check the file permissions and make sure they are accessible to the public, because they can't be accessed and come with a 404 error (missing file) when trying to be accessed.
Air Photo Colombia
by Air Photo Colombia » Thu Apr 14, 2016 10:31 pm
If you want i can send the files to you, we try whit 2 different servers and have the same results.
by Annis » Fri Apr 15, 2016 8:43 am
I don't have a server to upload the files on to.
Check your file permissions, or contact support from whoever supplies your hosting to help you access the files.
Air Photo Colombia
Re: Vr Mode don't work what we are doing wrong?  [SOLVED]
by Air Photo Colombia » Mon Apr 25, 2016 3:15 pm
Hi we find the problem, was so easy to solve, we are using a personalize template HTML from the las version of Panotour, we upgrade to the new templates and works perfect. thanks for your time.
