Can not zoom when viewing tour   [SOLVED] - View the solution
vicliciouss
by vicliciouss » Wed Apr 06, 2016 6:16 pm
Not sure if i miss some options of panotour pro. I can not zoom in - zoom out when viewing tour when use trackpad and mouse, only can use the button. And it only has one zoom level.
Please help me take a look demo at my site http://www.uyenstudio.com/du-an/dai-tie ... an-tp-hcm/.
Thank you,
Tuan.
Re: Can not zoom when viewing tour
by mediavets » Wed Apr 06, 2016 7:50 pm
vicliciouss wrote:Hello,
Thank you,
Tuan.
If you are using the latest version of Panotour then by default it will use the HTML5 viewer which cannot display multi-resolution for partial panos (those with a panoFOV of less than 360x180).
Re: Can not zoom when viewing tour  [SOLVED]
by Annis » Thu Apr 07, 2016 10:29 am
One of your panoramas is not a full 360, multiresolution partial panoramas are not supported in HTML5 so you are only limited to the resolution of the cube faces.
http://www.kolor.com/wiki-en/action/vie ... player_.3F
