Tour doesn't adjust to screen when mobile turned landscape?
chalkgsy
by chalkgsy » Thu Mar 24, 2016 3:42 pm
I've just been searching for some info on this and can't find any but it seems the tour I'm building at www.360ci.co.uk won't rotate to fit the screen horizontally when the device is turned on it's side. Is this a usual problem?
I have the gyroscope plugin setup so the funny thing is the video in the background turns and can be viewed in landscape but the overlaying footer, video bar, map and images remain in portrait mode, making everything look very bunched up and hard to operate.
Is there something i'm missing here or should this just work? I would have thought so as it seems quite responsive when re-sizing web browsers etc.
Re: Tour doesn't adjust to screen when mobile turned landsca
by mediavets » Fri Mar 25, 2016 11:08 am
What mobile device and OS and browser are you using to view the tour?
