Endless Background Sound only plays in opening pano   [SOLVED] - View the solution
rfendelman
by rfendelman » Tue Mar 15, 2016 6:07 pm
I've set Background Sound to Endless sound, but it only plays in the opening scene. When you select a spot to another pano, the sound stops. It does play whenever you return to the opening pano.
Of course I would like the music clip to play throughout the entire tour. Is that possible and how?
Re: Endless Background Sound only plays in opening pano
by Annis » Thu Mar 17, 2016 11:23 am
Where did you add the background sound?
The project properties or the scene properties?
Endless sound means it will loop.
If it's in the scene properties for your first panorama, then it'll be endless (looping) but if you change panorama it'll stop because that panorama doesn't have the music.
Set the sound in the project properties here:
http://www.kolor.com/wiki-en/action/vie ... ound_Sound
rfendelman
by rfendelman » Thu Mar 17, 2016 3:36 pm
Thank you. I added it in the correct place, but I did not realize that my video clips already had sound. That is why I was not getting sound in those clips. On each clip I see that there is a 'Mute' check box. When I check that box, my sound now plays throughout the entire Tour.
Question: What file or files do I need to update on my server now that I've made that change?
by Annis » Thu Mar 17, 2016 3:50 pm
If you've only muted them, just reupload the xml files.
http://www.kolor.com/wiki-en/action/vie ... oaded_tour
