how to change colour ov VR overlay?   [SOLVED] - View the solution
frank007
Likes: 12 posts
by frank007 » Thu Mar 10, 2016 12:49 pm
Hi folks,
maybe I am to stupid. but how can i change the colour of the overlay? I did not get it right. the coulour of the font is always the same as the overlay.
thank you!
frank
Re: how to change colour ov VR overlay?  [SOLVED]
by Annis » Thu Mar 10, 2016 1:10 pm
Open the YOURTOUR_core_vr.xml file
Search for <layer name="webvr_enterbutton"
Just underneath you should see bgcolor
Change that to the colour you want. For example, for it to be bright red, it would be 0xFF0000
Other settings like the font colour, thumbnail, etc are located in the same area of the xml.
