Logo not scaling to size on mobile screens
justinmih
Liked in: 3 posts
by justinmih » Fri Feb 26, 2016 4:06 pm
Hi
I am building a tour and need to add the company logo in the top right of the screen. The tour works well but the company logo remains the same size regardless of the screen its being viewed on. So on a laptop it looks great but on a mobile it fills pretty much half of the screen. I am using an iphone 4s on the latest IOS (although its the same on an iphone 6) and using Panotour Pro 2.5. I note on 2.5 that there is an option in the build tab "increase the scale on mobile devices and i have built the tour with this ticked an un-ticked and there is no difference noted between the two options. The logo setting in the style tab is set at 180 pixels wide by 120 pixels high.
Is there something that i can do to get the logos to re-scale based on the screen size being used similar to the way the menu bar works or is the only way to get this to work to use the percentage option?
If required the tour can be viewed at:
http://www.prophotocompany.co.uk/krpano ... wfaan.html
Thanks for your help.
Regards
Justin
