multiple parameters   [SOLVED] - View the solution
leifs
multiple parameters
by leifs » Tue Feb 23, 2016 10:56 pm
Yes, I've searched the forum and the faq's. But could not find the answere. So I try it her:
puting a pano online I can add a parameter like:
?flash=prefer
?s=pano130
and so on
but what if I want both ?
?s=pano130 xxx flash=prefer
what is xxx ?
I've tried ; and , and it does not cut it.
what is the right delimiter (if there is one) ???
leifs
leifs
Re: multiple parameters
by leifs » Wed Feb 24, 2016 8:10 pm
it seems like the right delimiter is &
like this:
http://www.rundskuer.no/panotour/groetd ... &s=pano130
leifs
Re: multiple parameters  [SOLVED]
by Annis » Thu Feb 25, 2016 9:46 am
You are correct, use "&" between deep-linking variables.
And you are right, the FAQ isn't clear enough. I've tried rearranging it a bit, is this better?
leifs
by leifs » Thu Feb 25, 2016 5:25 pm
the paragraph "How to force the display of the tour in Flash viewer or in HTML5" explains the parameters on /?html5, but not chaining parameters
the paragraph "How does deep linking work in Panotour Pro" explains deep linking and chaining of deep-link-parameters
my case is chaining html5-parameter with deep-link-parameter. looking at the first paragraph I didn't find anything about chaining, I should have looked at the second paragraph and guessed that & also can be used for "combined chaining" for html5 and deep-linking.
btw:
the first paragraph explains ?html5=prefer
I use the "inverse parameter", not documented, ?flash=prefer !!
the reason ? partial panoramas produced with PTP 2.50 behaves mediocre with html5, much better with flash ! therefore I want these panos to be shown using flash, if available. therfore ?flash=prefer
