VR Mode Button does not show up
Alain
by Alain » Fri Feb 19, 2016 1:47 pm
Hi
I'm testing Panotour 2.5 Beta 4.
I've "VR-Mode for Desktop" activated and added a "WebVR Button" from the Plugin-Library.
But when I open the Tour (saved on my local networkdrive) in Firefox Nightly Build ("Mozilla WebVR Enabler" Plugin is installed), then the "VR-Mode Button" does not show up.
Any Idea what I do wrong ?
Kind regards
Alain
Re: VR Mode Button does not show up
by Annis » Fri Feb 19, 2016 1:55 pm
Why use BETA 4? The final version has been released: http://www.kolor.com/2016/01/14/virtual ... 2-5-final/
You don't need to open the tour in a WebVR browser unless you're going to view the tour in the Oculus.
When viewing the tour locally you have to view the tour through a local webserver.
Does the button show up when you click on the green 'play' button in Panotour (View last built tour button), or if you view the tour through the KrPano Testing Server. http://www.kolor.com/wiki-en/action/vie ... ing_Server
PS: I've moved your topic, you posted in this in the Autopano forum.
Alain
by Alain » Tue Feb 23, 2016 11:55 am
I've installed the Final release of 2.5 (I guess I found a "BETA 4 2.5"-Link somewhere which directed me to the Final 2.5 Version. That's why I thought that I'm using the BETA 4).
I wanna view the tour with the Oculus and/or Cardboard via the Webbrowser (either locally for testing or on any webserver on the www).
Why do I have to install a local Webserver ? HTML and CSS should run without a local Webserver, or does KrPano use any PHP ?
I've tested the tour on a Webserver as well (uploaded it to a webserver in the www) - I guess this has the same effect as when I would use the "KrPano-Testingserver" locally. But the button still doesn't show up.
If I click the "green Play button" in Panotour, then the button doesn't show up as well.
Maybe I've missed something in the buttonsettings ?
Current Settings:
Edit 23.02.2016/12:32:
When I test it on a Webserver on the www with "experimental builds of Chrome" then it works.
But when I try it locally with "experimental builds of Chrome" then I get an error:
Alain
by Alain » Thu Feb 25, 2016 7:26 am
Has anyone an idea what I do wrong ?
Kind regards
Alain
Alain
by Alain » Thu Apr 21, 2016 8:43 am
I tested it with "KrPano Testing Server" but it does not help.
The VR-Button does not show up (using Firefox now).
Can somebody please help me ?
Thanks in advance.
Alain
