¿Panotour support Oculus Rift?   [SOLVED] - View the solution
rrmontero
by rrmontero » Fri Feb 19, 2016 11:31 am
I want to create a virtual tour whitch I can see with Oculus Rift glasses. Is it possible? If is possible, what do I have to do?
Do exist any documentation about this?
Thank you very much.
Re: ¿Panotour support Oculus Rift?
by Annis » Fri Feb 19, 2016 11:39 am
See here: http://www.kolor.com/wiki-en/action/vie ... patibility
You need to build the tour with Panotour Pro 2.5 to get VR Mode, add a button to access it and then you need a browser that supports WebVR (see link in the documentation).
rrmontero
by rrmontero » Mon Feb 22, 2016 1:50 am
thank you Annis.
And interactive points, how can I activate with the glasses? How can I click on points?
Re: ¿Panotour support Oculus Rift?  [SOLVED]
by Annis » Mon Feb 22, 2016 11:23 am
The interactive points are your navigation hotspots. You move from one panorama to another by staring at it!
If you have a look at the page I linked you, it explains how you could create a VR Mode specific navigation.
