Buggy Analytics Plug-In (?)   [SOLVED] - View the solution
panoramer
by panoramer » Mon Feb 15, 2016 11:29 pm
Hey guys,
first of all I would like to tell you that I really enjoy using your products. I'm working with APG about five years now and each version is getting better and better. Thank you!
Since a few weeks when I managed to upgrade my PTP I encountered a "bug" with the Analytics Plug-In: Where is the insert code and how to change the parameters (e.g. anonymizeIP_ for european usage)?
Thank you!
Kind regards
panoramer
Re: Buggy Analytics Plug-In (?)
by panoramer » Fri May 20, 2016 5:08 pm
Does nobody have an idea? :(
ajh
by ajh » Thu Sep 22, 2016 6:03 pm
There is a bug, I just got off the phone with Google and they confirmed that the code isn't in the right place. For some reason the Analytics plugin doesn't place the code in the header, so it is tracked in the live overview, but doesn't get recorded in the rest of your analytics.
panoramer
by panoramer » Thu May 24, 2018 9:04 pm
GDPR is live tomorrow and still no solition on anonymizing IP Adresses?!
Re: Buggy Analytics Plug-In (?)  [SOLVED]
by benji33 » Mon Jul 30, 2018 8:59 am
Latest version of Panotour apply this change into the Built-in plugin.
