Embedded pictures are sideways   [SOLVED] - View the solution
nwbandrew
by nwbandrew » Tue Feb 09, 2016 9:57 pm
So I'm trying to add a photo using the "add photo" feature to embed one into one of my panoramas. For some reason it keeps turning the photo sideways. I've tried adjusting the size of the embedding area, and I've also tried rotating the actual image file, but nothing seems to work. I can't find anything that will fix this in the style editor either. I did manage to make it so that if you click on the image to maximize it, it rotates it and looks normal. I set a maximum width to accomplish this. However, I would prefer to just have it not rotate at all and just look the way it's meant to in the first place.
See below for my style settings.
Any help would be much appreciated!
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
Re: Embedded pictures are sideways  [SOLVED]
by Cliquetsy » Tue Feb 09, 2016 11:08 pm
Users browsing this forum: No registered users and 10 guests
